landyacht318
Oct 02, 2014Explorer
Revenge.
It can be so sought out so desirable, so coveted, and worth so much, or so little, once complete.
My last charge plot, as in I have no intention of observing and recording data every 5 minutes through out another charging cycle, again, well anytime soon.
This was the screwy 31, 44 AH from full, reading 11.9v under an 8.7 amp load right before attaching MW.
I set MW Terminal Voltage to 15.00, then plugged it into Screwy 31.
Once again the IPN V and A are battery voltage and amps into battery measured by my IPN Pro remote battery monitor.
GTP V and A are the gtpower meter volts and amps
MWTV= MeanWell output Terminal Voltage
I was going to plot temperature, then realized how much I never want to make another chart again either.
At ~1:10 into test, I noticed IPNV touched 14.8, and lowered voltage trim pot, thus the spike and dip in voltage mid chart, but amps were already in sharp decline at that point.
I really wish the IPN had 2 decimal places.
But, Gefwif
But, Gefwif
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 10, 2026
