MEXICOWANDERER
Jun 24, 2016Explorer
Found a source for "ON" brand Bipolar transistors rated almost 40% higher amperage with gate specs compatible with the OEM transistors. Not cheap. Around $8.00 each.
Your battery shots reflect the higher impedance of other than Lifeline batteries. I can hammer mine with over A HUNDRED AMPS for fifteen minutes and the temp will gain 11-14F over ambient. This is measured at the terminals not through a thick plastic jar wall.
The BORG is getting a 215 CFM 120vac fan. An EBF PABST dual ball bearing brushless. Being a charger, noise does not bother me. The noise could resemble a diving Luftwaffe Stuka, during the blitz and I could care less.
I love your posts Landy! I just purchased a quarter-pound tub of silver heatsink compound that significantly out-performs Arctic Silver.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
