RoyB
Sep 23, 2013Explorer III
I just look it up on the specification sheet...
This is for the TROJAN T1275 - says this battery will produce 12VDC@25AMPS for 280 minutes or 4.6 hours... At the end of 4.6HOURS this battery will be reading 10.5VDC if you put a 25AMP load on it. This tells me I will only be able to use this battery for 2.3 HOURS of 25AMP DC drain if I want to recharge again at the 50% charge state.
These are the rules I follow at any rate for estimating battery capacity and it seems to pan out pretty good... I will re-charge when my battery voltage drops to appx 12.0VDC according to this chart
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
