MEXICOWANDERER
Jul 19, 2020Explorer
Dealing with multiple disciplines is never easy.
If you yourself will spend some time with a hydrometer and verify voltage on your meter to the actual state of charge you will have a system as good as any simple measurement around. Even an amp-hour meter needs to be "zeroed" once a month, using a hydrometer.
AGM batteries are easier to manage
Lithium is impossible without an amp-hour meter system.
This is like answering a "Celestial Mechanics Made Easy
Or learning phasor algebra in 3 days question.
Or the fraudulent "Learn Spanish Using 5 Easy Tricks"
A weekend of using a voltmeter and you won't get in trouble. Try it for a month, 100% boondocking and you will end up on **** Cree. I put the asterisks in.
