full_mosey
Dec 17, 2012Explorer
HiTech;
No matter what season, you will benefit from Southerly tilting of your panels at your Latitude.
If you have a favorite orientation to park your trailer, you will benefit by using the direct adhesive mounting on the Southerly tilted side.
If you want to understand the benefits of tilting, check out this solar tilt calculator.
Step 3. tells you what you what % of available insolation you can expect if you do not tilt.
HTH;
John
HTH;
John
