DrewE
Jan 12, 2016Explorer III
Chum lee wrote:
I agree with Matt Colie and Canadian Rainbirds. I was thinking of the same comparison. As an avid road bicycle rider for 30 years, I know that even the best world class riders/athletes can generate about 1/3 hp continuously using their legs with short bursts slightly higher.
Remember that although 1 horsepower is numerically equal to 746 watts, if you measure the wattage to run a 1 hp (120 volt) single phase motor, even the most efficient motors require about 1550 watts at full load due to mechanical/electrical conversion losses. Three phase motors are slightly more efficient.
Solar panels are looking better and better.
Chum lee
I don't disagree with your conclusions or basic argument at all; however, electric motors are not quite as inefficient as you're suggesting. 80% or 85% efficiency is a not unreasonable estimate for a good quality 1HP single phase motor. The apparent power consumption, and hence current requirements, will be higher due to the relatively poor power factor. NEMA specifies a 78.8% minimum efficiency at full load for standard "design B" 1-4 HP motors.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
