MEXICOWANDERER
Mar 31, 2018Explorer
- Would you care to do a little investigating to determine "what went wrong"?
- Where was the device placed and how did you mount it?
- What kind of generator was powering the device? Was the generator loaded or unloaded?
- Have you verified the generator speed (frequency) was 55 to Hz?
- How about voltage loaded and unloaded?
- GCFI Circuit breakers are normally rated for 15-amps. As the green white and black wires enter the Megawatt case, the very first thing they encounter is an axial lead read-precision, fast acting tubular fuse rated 10.0 amperes, then comes a pair of MOVS.
Yes the factory rating of the Megawatt 400 is 30 amps. I have nine of the units. And have extensively modified 3 of them to produce as much as 55 amperes 24/7/365
My interest in this is to determine "What went wrong". Too many units have gone too long on much higher load amperages to consider what happened to your Megawatt "normal". The one that failed to my knowledge was set flat on a hard surface then charged at full capacity of 40+ amperes for days, trying to keep up with several 8-D batteries.
Are you willing to work with me on this? It would involve you shipping the charger to the San Diego area. This is not an offer to gruesomely poke the corpse and see if it twitches.
Check the stuff I listed above on your rig if you would be so kind. There was a $22 dollar junko Chinese clone of this machine that went further and worked harder than your 65 dollar unit and frankly my eyebrows are up to my forehead. But I am an old wizened-fart. I will wait to read your reply before moving on this :) A genuine offer to help...
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
