MEXICOWANDERER
9 years agoExplorer
Megawatt Dissection & Notes
This is "Jim In Denver's" unit.
Circuit board fuse found to be "good"
One 330 uf cap has a domed top. My ESR tester located far far away.
Bridge rectifier tested good
Bi-polar transistors: One shorted. One open. 2-remaining tested questionable
Quality of electrolytic caps could be better. Low ESR Panasonic caps will replace. Will try for 330v rather than 200 volt if they'll fit.
TI and ON both make same-case higher rated bi-polar transistors. I'll replace Q-1 for drill as well.
Heat sinking needs help. Thinner, better thermal rated sil-pad material. Silver instead of zinc-oxide thermal paste.
Fan vent as usual is a joke. Will chop out the slots and open things up and replace with a wire fan guard.
Don't know how I managed to run out of solder-sucking braid. This is not the place to run out of anything.
UNRELATED. Found 15-amp board fuse of 55 amp Whiffie blown. That's a lot of wattage. Unless some techhie forum member comes forth and says "Hey that's not unusual!" I am tempted to not waste 5-minutes of time troubleshooting the unit. The Schizophrenic Design is not worth repair. This is an older unit.
