myredracer
Mar 30, 2018Explorer II
Chum lee wrote:I don't think this is the most likely cause. It can also be caused by a failure to keep the plug blades clean or plugging in live. Any photo I've seen of burnt blades is just about always the neutral blade like the examples below. If it was due only to a bad receptacle that is being plugged into, you'd see just as many burnt hot blades or both neutral and hots. Not sure why just the neutral would be affected. Also sometimes happens to the twistlock end of a cord which obviously doesn't have anything to do with a pedestal.
The damage you see on the plug provided in the OP's pictures was most likely caused by a bad female receptacle.
Chum lee
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
