dougrainer
Jul 27, 2018Nomad
OK, The pics show the CHASSIS side Fuse block assbly. 1999 HR we will assume it is a ROADMASTER chassis. The Fuse blocks look just like Freightliner Fuse blocks and hopefully Monaco(Roadmaster) used the same supplier for the chassis harness and fuse blocks that Freightliner used. The problem with the current version of Monaco is, MOST of their help were probably not born when some of the older Monaco/HR's were built:B So, they have no knowledge of Roadmaster or any other older systems that the original Monaco/HR had. Maybe if you approached the problem by taking the pics to Freightliner and attempting to cross reference a 1995 to 1999 chassis harness Fuse block you may get some help. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 10, 2026
