Old-Biscuit
Feb 17, 2017Explorer III
pianotuna wrote:
The reason for the question is someone has given me a water bed heater. It is a large flexible pad. In testing it gets up to 166 f (76 c).
Are the holding tanks ABS or are they polyethylene?
ABS.....waste tanks
IF you plan on using that water bed heater then you need to use a thermocube to control on/off temp
TC-3 would work (on at 35*F/off at 45*F)------rv waste tank heater pads turn on at 40*F off at 60*F
but the TC-3 thermocube would keep liquids in tanks from freezing
Thenocube
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
