howardwheeler's avatar
Aug 10, 2020
Merging a Xantrex SW2024 to a Tesla Lithium battery
I have a Xantrex SW2024 that states in its manual that under a custom battery setting that the bulk charge can be set anywhere from 3v to 32v. It also states that when the voltage rises to the absorption voltage that it will switch to absorption from bulk. Well, unless we are really missing something, it appears neither is the case. Multiple calls to Xantrex have been fruitless. Problem? I have installed a 24 v Tesla in the place of four size 31 FLA batteries. Everything is working great on my solar charging system, and we were able to program it perfectly to the Tesla parameters. Not so the Xantrex in spite of its clear statements in its manuals. We cannot get it to be set below a bulk rate of 27.2 v which will fry the Tesla. We caught it before catastrophe. But I need to occasionally be able to charge from shore power via generator or plug in. But I'd have to sit there watching the charger to make sure the voltage does not rise above 25.2 We have an automatic shutoff solenoid attached to our BMS in case we overlook it sometime, but that shuts everything off. So two questions: Does anyone know how to set the bulk limit to 25.2, or second, does anyone know why it does not shift to absorption when the absorption voltage threshold is reached, which would effectively limit bulk voltage to safe levels even if we couldn't actually set the upper limit to bulk voltage? Does anyone understand Xantrex inverter chargers well enough to give us some clue as to why you cannot harness the bulk voltage to a 25.2 volt limit? The battery works great by the way, and I've shaved 479 lbs of my pin weight by removal of the FLA batteries and generator. I'm happy with the battery but perplexed by Xantrex.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
