CA_Traveler
Jun 29, 2016Explorer III
Wondering if you connected all cables when you replaced the batteries?
BIG HINT: Always mark all cables and take pictures before you start. A club members friend replaced his batteries and the rig would not start. He was in total denial that they weren't connected correctly. After he finally calmed down and let me look I found a unconnected cable.
The combiner or boost is a solenoid that connects the 2 battery banks. It should be reasonably close to both battery banks.
OP Your unloaded voltage readings don't mean much. Connect your voltmeter to a good FRAME ground. Then when trying to start measure to the negative battery post (should be almost 0V) then the positive battery post (should be 12V+). Continue towards the starter until you find the problem.
New batteries fail - have them load tested.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
