doublev
Jun 29, 2016Explorer
I purchased new battery post adapters to replace the old ones today. Cleaned all wiring up. Still the same problem!
While doing this I turned off the chassis battery. The dash is completely dead. SO obviously it is getting some power when the batteries are hooked up and on.
I fired up the coach with the battery boost and then took a reading on the batteries. 12.70Volts. If the engine is running, would you expect to see 12.7V or should there be a higher reading because they are being charged?
Also.. when the coach is hooked up to shore power, wouldnt you also expect a higher reading (something like 13.6) because there is no load on them and they are presumably being charged? (or maybe they are in taper/float mode so it wouldnt be so high?)
I am not sure what to do here.. the batteries were working fine and now they are not cranking the engine. They also dont seem to be getting a charge? But they are not completely disconnected because the dash sees them.
I am trying to find the battery charger and I cannot find it on the coach. I thought country coach had a dedicated charger for the bank. But could I be getting 12.7V and the batteries are too weak to crank the engine (nothing from the starter)?
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
