thanks road runner, that is a very good point. in the nice weather right now, it was drawing about 11 amps so when it is a 100 here, you are right, things could be different. i am very sure it will run my 13,500 thought at 100. what i really like is that it will start with only one generator.
i had a inductive amp meter on mine and before i put it on, my 15k was taking 45+ amps to start, now it is at 21 amps. less for the 13,500.
but i think easy start or not, can't do much with the outside temp conditions so it will build up head pressure
right now my head pressure seemed to level off (in amps) at about 11.7 or so, leaving me 3 or maybe 4 amps for the hot weather coming.
the way i understand it is that the wave has to hit the motor at like 90 degrees for the best possible "pushing" and i think the easy start finds the best wave to do it. feel free to keep in touch maybe via private message? would like to compare notes. thanks
