StirCrazy
Apr 15, 2023Moderator
Micro Air
Hi, just looking for input from people that have them on their effectiveness. I am thinking of getting a portable genny for the 5th wheel for those times that I need an AC and don't have power. I ha...
JBarca wrote:StirCrazy wrote:
Hi, just looking for input from people that have them on their effectiveness. I am thinking of getting a portable genny for the 5th wheel for those times that I need an AC and don't have power. I have a 15000BTU dometic AC, and I must figure out what size genny I need also.
As some of you know I personally hate the noise they make, so it must be quiet and really won't be used for anything else as my solar can do everything else. the other issue I have is there has only been 4 days in the last 5 years of camping where I needed an AC when I was boondocking, so I am really torn weather I need a genny or just see what it would take to be able to run on solar, but I think it's too tall of an order for solar.
Hi,
You might have sorted out your issue already, but I'll add this to help the cause. I just added a Micro Air to a Domeitc 15K commercial AC, and I have some data to share.
I have an older Honda 2000I genny. It is a good genny and served me well. I am sharing the data from the genny and camper working at about 500 ft elevation in central OH. So take this into account if you are going up in higher altitudes.
This snapshot is from an older 2003-made Brisk Air 13.5K with the compressor start assist the capacitor added to the fan and compressor's split capacitor. I cleaned the coils and tested the amp draw after the cleaning. This meter has a peak hold mode to it. Plugged into shore power, the power converter was on, and the AC in auto. This is the spike the compressor made for that split-second inrush,
I wanted to know if my 2000I could start that 13.5 AC, so I did this test. This is still the 13.5K AC noted above.
The power converter was shut off, and the Honda 2000I was in run mode (fast speed). I was using battery power to run the AC controls, and the AC fan was already running, and then I kicked on the compressor. The 2000I did start it and ran, but the genny was giving all she had to give. Again, there was no power converter running on AC. This test told me this is not a great setup for boondocking now with my genny, even though it did work. If I had to charge my battery, that extra overhead on the converter most likely would have overpowered the 2000I
The 13.5K Dometic died, and I upgraded in May, 2016 to a Dometic 15K commercial Brisk Air. This is not the standard RV AC; it is built much better; food trucks use these etc. Here is the name tag on this AC. It is a 479 series AC. The new Brisk Air II commercial replaced this 479 series, and, in my view, it is not as good, but that is a different story.
I installed the Micro Air three weeks ago and redid some genny tests using this 15K commercial AC unit. Here are the results.
This 15K AC does not use the 2nd compressor assist capacitor. It only used the single split capacitor for the fan and compressor. The motor is efficient enough not to need the extra boost.
Here is the amp draw of my Progressive Dynamics power converter hooked to 2, 100% SOC grp 27 batteries. Not much, 0.62 steady amps; I'm showing this as this shows up in the amp meter readings. The AC unit is not on yet, nor is any other AC device in the camper.
Here is the Honda genny when I tested powering the camper
Here is the Micro Air upgrade,
I did the five start tests the Micro Air needs to teach the unit on power loads on shore power; then I converted to the genny for the next tests that may help you. The genny is in ECO mode during these tests and will respond as the power load changes.
The power converter load of 0.62 A, the fan running, and the compressor running on the 2000I were 11.6 Amps steady.
Now to the compressor spike with the Micro Air. Let's compare the 37.04 amps spike on the old 13.5 across-the-line compressor start to the Micro Air start spike on the 15K commercial unit with the fan and 0.62 amp power converter running on the Fluke amp probe, 19.3 amp peak.
Here is the Micro Air readout stating 18.0 amps (I bought the blue tooth version to see this on my phone). Note: this is only the micro air spike; the Fluke has the power converter overhead included.
This is a video of the Fluke test with the genny running, the power converter running, the fan on auto, and the compressor kicking on and then constantly running. This video links to my Flickr photo site, where the video is stored. Once on the site, double-click it, and the video should start
https://www.flickr.com/photos/camper-johnb/52834495337/in/album-72177720307672421/
Adding the Micro Air, my 2000I will run the 15K Dometic commercial unit with the power converter only drawing 0.62 amps. I can tell by the sound of the genny it is more speed than the normal ECO mode, but it is not wide open. The Honda is modulating the speed to match the load. When we boondock and charge batteries off the genny when the wife runs the microwave, that uses all this 2000I has. The Honda ramps up to wide open until the microwave drops out of full power, then back up the next full power burst. The AC unit with the Micro Air works better than the microwave.
In my situation, at lower elevations, I have a working situation, but... there is always one of those buts... the power converter; if my batteries are down to 50% and I'm recharging them, the power load from the PD converter will go up, and pending how high that goes, I can run out of the generator. The point is, yes, a Micro Air can run a 15K AC unit at lower elevations, but don't forget what the power converter will be using.
When I bought my Honda 2000I years ago, they did not have the 2200 version available, and I convinced myself I did not need AC where we boondock. Well, times change, and so does where we boondock. I sense a Honda companion generator in my future or an upgrade to a 3000I unit.
I hope the data helps you with your solar recharge etc. I have not made the solar leap yet; we camp under many trees on the east coast when we boondock. When we head west a lot, I'll rethink the solar.
John
