StirCrazy's avatar
StirCrazy
Moderator
Apr 15, 2023
Micro Air
Hi, just looking for input from people that have them on their effectiveness. I am thinking of getting a portable genny for the 5th wheel for those times that I need an AC and don't have power. I have a 15000BTU dometic AC, and I must figure out what size genny I need also.
As some of you know I personally hate the noise they make, so it must be quiet and really won't be used for anything else as my solar can do everything else. the other issue I have is there has only been 4 days in the last 5 years of camping where I needed an AC when I was boondocking, so I am really torn weather I need a genny or just see what it would take to be able to run on solar, but I think it's too tall of an order for solar.
  • I have one installed on my Dometic 13,500 BTU AC. The AC runs OK on a Sportsman dual fuel 2200 watt generator running on propane. Another advantage is the "thump" as the compressor comes on is gone.
  • 15k AC will pull 1600 to 1800 watts. About 14.0 amps. So, base the size of your Genny on that. Doug
    Surge start up, about 1900 watts
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
