SoundGuy
Sep 25, 2016Explorer
pnichols wrote:
I also have to order a new valve, remove the old valve, and install the new valve. This is a VERY DIFFICULT job because of the close quarters in behind the toilet. I have to go pretty much by feel, use a mirror, and use a headlamp for light. I refuse to remove the toilet just to do this, even though it's difficult ... as that would be even more of a nightmare task.
You sure are insisting on turning this simple task into a monster it need not be. :S Turn the water off, undo the two flange bolts securing the toilet, and lift it out so you can work with it on your workbench. It's only a "nightmare" if you make it one. :R
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
