Seabass69's avatar
Seabass69
Slide out motor assembly?
I have a 2004 HR scepter and a slide out broke. After getting it apart it appears a small bearing on the slide mechanism broke and a tooth on the main drive gear broke. Where can I find these parts? I have been looking on the net with no results. Thanks
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I took old parts to a machinist. he did a fantastic job.
    I've done this on two occasions with different gears and parts.
  • Thanks. I was thinking I may weld it up and file it down myself. Doesn’t seem to be a gear in stock anywhere
  • take the bearing down to a auto parts store and see if they can match. The gear, might need a machine shop if you can not locate one.
  • Send your pictures and info to Lippert. If they answer you (50/50 proposition), whoever answers you knows what they are doing (Another 50/50 proposition), and actually still make or have the parts (50/50 again) just be ready to give up your first born to pay them. They charge $20 for a screw.
