CJW8
Apr 16, 2016Explorer
Inverter generators: The engine is connected to an efficient alternator whose output is converted to DC by a rectifier and smoothed somewhat by capacitors. This raw DC power is then inverted into smooth AC power of the proper frequency and voltage for the output (for example 110-120VAC 60HZ or 220-240VAC 50 or 60 HZ). Regulation is very good and the system will use less fuel if the load is small or variable since the control system will allow the engine to idle down when the load is small or throttle up when the load is large.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
