Sam_Spade
Apr 16, 2016Explorer
mikakuja wrote:
Just remembered that someone asked what the mic was doing... Basically as soon as I hit the power button the mic starts then the lights dim on the display and bulb inside then the mic simply shuts down and resets itself. While this happens the gen will spool up and then back to normal rpm (econo turned off).
It would be REALLY informative to see what the input voltage does when that happens.
Like I said before, replacing EITHER the microwave or the gen would probably solve the problem.......but my guess is that the microwave is drawing more than it is spec'd for.....due to age maybe.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
