mikakuja
Apr 22, 2016Explorer
Well, I have gone through my entire system and I am leaning toward the mic being the problem. I have not tested the actual power being drawn by the mic but did play with it a bit on shore power and although it always works on shore power it sometimes kicks on without issue and other times the lights dim quite a bit... I am going to pick up another mic and hope for the best, if that doesn't work I will upgrade the gen. I did find that the power plug on the gen needed replacing as the vibrations from the engine would cause the plugs to fall out... Replacing the plug made no difference to performance, although it is nice that the plugs stay plugged in.
Other than that I have switched gears and installed two 12v 100 watt Mono panels and a 20 amp MPPT Tracer controller this week... Lovin it already...
