Sam_Spade
Apr 22, 2016Explorer
mikakuja wrote:
Well, I have gone through my entire system ....
If that is true then you should have some input voltage readings on the AC feed when the microwave fires up and when other things run......but you seem to be reluctant to share those readings with us.
If you haven't watched the input voltage, why not ? More than one of us has suggested you check it.
