MEXICOWANDERER
Jul 21, 2017Explorer
It takes well in excess of 200 volts RMS to damage an OEM laptop brick (despite what its label may say).
You need "proof" an that proof can be best created by use of a multimeter and cellphone camera. Have a 2nd help with the images.
Meter probes stuck into campground receptacles. Image shows probes, receptacle and meter reading. Same with block type plug-type connection verifier. With meter get L1 to L2 voltage. L1 to LO and L2 to LO. L1 and L2 to socket earth ground ground. Socket earth ground to actual ground around your feet.
I would not give advance warning. Turn images into glossy photographs. Then present management with a stack of photographs at your first announcement. They'll hate that for good reason. Attorneys despise documentation for a reason.
Good luck.
Good luck.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
