Mike_Schriber
Jul 22, 2017Explorer
That makes sense. I just checked the pedestal and it seems fine. One leg has lower voltage than the other but I'm pretty sure that doesn't indicate anything in particular. I thought I got an open neutral on one leg but it went away. It could have been probe placement or a transient. I can't be sure. I really have no way to test my cord either so I'm stuck. I might experiment with some load tests using a heater and see if I get a failure again (with everything else unplugged)
Keeping the rig plugged into the 30 amp outlet via an adapter for now.
wnjj wrote:Mike Schriber wrote:
Thanks for the feedback. I am using one of those three light testers. I keep one in the rig as a quick and convenient way to see if an outlet has power. The reversal indication was a surprise. At the time no other AC appliances were running.
I'll be checking the pedestal with my meter this morning for a more in depth assessment. I'll also look over my cord.
The AC likely pulled enough current through the compromised neutral to finish opening it up. Once open, a small draw on one leg in the RV will keep the neutral pulled to one side (showing hot-gnd reversed) even with the AC now off.
It's a bummer situation and I wish you the best.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
