pianotuna
Jul 23, 2017Nomad III
Hi Mike,
I wish that were so--but the 30 amp shore power can be on either the high or low voltage side of a neutral. It is rarer, but not impossible. That is why I always check voltage and polarity under load before I plug in the RV.
BTW I'm not a surge protector believer, but rather an energy management believer. Mostly low voltage is what causes slow but progressive damage to items such as the air conditioner. That is why the first line of defense is measurement under load, before plugging in the RV. The second line is a Sola Basic autoformer which does 3 layers of boost and 1 layer of buck.
Mike Schriber wrote:
Assuming that it may be my plug that's defective, if I continue to only use the 30 amp adapter that should prevent a similar overvoltage from happening again right?
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
