MEXICOWANDERER
Jul 23, 2017Explorer
Ratz!
Well it was worth a look I suppose. My commercial 1,875 watt LG has two fuses and a disconnect breaker. The unit has to be unplugged to reset the breaker which is rated 5 amperes less than the main power fuse. Just as a note it takes three separate programming steps to exceed 1,200 watts power. It will boil a liter of water somewhere in the neighborhood of 60-seconds. it demands a 20-amp receptacle. Which do not exist down here. The 15-amp pictogram with red circle and bar showing a standard 15-amp receptacle is how the unit was discounted to me. I picked it up brand new for around $108. Stainless steel cabinet and membrane touch pad. It has a built in 2032 three battery memory retention.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
