Bobbo
Jul 23, 2017Explorer III
pianotuna wrote:
I wish that were so--but the 30 amp shore power can be on either the high or low voltage side of a neutral.
Correct me if I am wrong, but on a 30 amp circuit, you have a HOT and a NEUTRAL. If the NEUTRAL loses connection (which is what happened to fry his stuff) you have NO CONNECTION. You can only have the 0v and 240v (or low voltage/high voltage) difference if you have both HOTs connected with no NEUTRAL.
Of course, if the pedestal is miswired (e.g. a HOT/NEUTRAL reverse) all bets are off.
wa8yxm wrote:
Longer anser
On a 30 amp RV it may well work out the same way only now you and a neighbor share a "Neutral" (The neighbor may be some distance away) so either NOTHIGN works (That's safe) or you see the same thign happening to your RV when HIS A/C kicks in.
Question. If you and a neighbor are sharing a NEUTRAL, and you (or he) loses the NEUTRAL on a 30 amp system, what is the return path that allows the current to flow into your HOT wire at 240v (ish)?
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
