MrWizard
Aug 18, 2018Moderator
you need someone with electrical experience to help you
from the sound of it you have lost the "pass-thru" of power, on the outlets fed by the inverter, there should be some push button circuit breakers mounted on the inverter/charger combo
example our previous RV a 95 Safari DP
TV, (1) kitchen outlet, bath outlet, (2) bedroom outlets, and kitchen ceiling fluorescent light, where on the inverter, this was the drivers side of the RV
every outlet on the curb side was shore or generator, not wired to the inverter
your batteries are charging from the inverter AKA No Solar ?
then the inverter has power input, but no power output, no pass thru
