Discovery8's avatar
Discovery8
Microwave and TV Power - Need help troubleshooting
I'm getting power to the MH. The microwave and both TV's in living room and bedroom went completely out. I was plugged into shore power when they went out.
Any ideas/advise?
Thank you.
  • did you check the circuit breakers inside the coach AND outside on the inverter?
  • Discovery8 wrote:
    Mandalay Parr wrote:
    Circuit breakers on inverter if you have one.
    Circuit breakers are on.
    Are you sure? Most circuit breakers these days when tripped need to be flipped all the way off before being turned back on to re-engage. A tripped breaker won't necessarily look like it has been tripped.
  • Are you positive? Many times a CB canmlook on and be teipped. Turn them all off and reset.
  • Checked circuit breakers, shore power pedestal, GFI and fuses?
