- Discovery8Explorer
Optimistic Paranoid wrote:
I'm afraid this thread has left me a little confused.
You were plugged into shore power when they went out, so what do your house batteries have to do with it? Weren't the appliances running directly off the shore power?
Yes, I was plugged into shore power. Sorry for the confusion, I am not knowledgeable with the electrical on the MH. We've noticed our interior lights started dimming a few weeks ago and the last time our lights did this a couple of years ago we replaced the house batteries and it fixed the dimming lights. Just thinking of other possibilities but like I said I'm not knowledgeable with the electrical. - Discovery8Explorer
PaulJ2 wrote:
Maybe area power outage? Anybody near you have power?
There is no power outage. - Discovery8Explorer
Agree. Microwave runs on 120 vac, not battery. Look for tripped GFCI outlet. Or if on 50 amp service, check to see if you lost one leg of the 50 amp outlet.
The GFCI outlet is completely out, no power. - Discovery8Explorer
pianotuna wrote:
Welcome to the forums!
Is the RV a 50 amp service? YES
Do any of the power outlets work? YES, SOME WORKING OTHERS ARE NOT
Is the battery bank being charged? YES
Do you have a way to measure the voltage at the outlets? (for example, a kill-a-watt meter)? YESDiscovery8 wrote:
I'm getting power to the MH. The microwave and both TV's in living room and bedroom went completely out. I was plugged into shore power when they went out.
Any ideas/advise?
Thank you. - MEXICOWANDERERExplorerYou've done just about everything you can do. I sure as hell am not going to advise a novice to go behind the circuit breaker panel. But that is where I suspect the problem lies. You need someone experienced to help keep you from being electrocuted.
- 2oldmanExplorer II
Discovery8 wrote:
The charger in the inverter? Sure. Get out the voltmeter and check your batteries.
We have noticed the interior lights in the MH have been dim for the last couple of weeks.Could it be the inverter went bad? - CA_TravelerExplorer III
Discovery8 wrote:
Yes. If you have a pass through inverter then it could also be it's input CB as well as the related panel CB.
Recommend you get the batteries charged while finding the problem.
Always helpful to post what you have like: mfg model xxx charger/inverter yyy watts etc. - 2oldmanExplorer II
pianotuna wrote:
I wired my prosine that way to act as a power minder but it was easy enough to verify with a voltmeter at the pedestal if it was refusing shore.
A few (nutty) inverters are hard wired in place and the power flows through the inverter first--I think this is a stupid design choice.
And I've never heard of an inverter with breakers on it. - Discovery8ExplorerWe have noticed the interior lights in the MH have been dim for the last couple of weeks.
Could it be the inverter went bad? - pianotunaNomad IIIWelcome to the forums!
Do you have a way to measure the voltage at the outlets? (for example, a kill-a-watt meter)?Discovery8 wrote:
Any ideas/advise?
Thank you.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
