BFL13
Mar 08, 2018Explorer II
How is the inverter 120v side wired up for what appliances are on what? IE is the MW on a different sub-panel from the other things that work ok? Try plugging in the MW to a receptacle that runs the kettle ok and see if the MW runs ok there.(will need an extension cord )
What is the 3a on standby compared with the 6a water heater? 3a 120v??? Makes no sense. Inverter on standby, no load, would have maybe 1/2 an amp DC although inverter/chargers seem to have more what with their extra "features".
What is the "output" all about? Not following. :(
Like the others, I have no problem running the MW with a 2000w inverter. But I don't have a remote display and transfer switch and relay etc. I plug the shore power cable into the Inverter and shut off the converter etc manually.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
