j-d
Apr 10, 2017Explorer II
Daughter had a beautiful Kenmore under-counter micro that was made by LG. It displayed an error code that turned out to mean the Inverter Section had failed. It turned out that "they all quit that way" (or at least close to it) and repair exceeds cost of a new microwave. So we junked it and bought a Whirlpool non-inverter replacement at Lowe's.
Inverter IS a nice feature. Without it, when you set a 1000 Watt Micro at Power Level 50-pct, it runs at 1000 half the time, On, Off, On, Off, etc. When you set 1000 Watt Inverter at 50-pct, it cooks at 50-pct for the whole time it's set for. The big benefit for an RVer, is being able to run at less power consumption to come in under that capacity of a generator, 30-amp shore tie, etc.
Because of the common LG inverter failure, gOOgle around, read reviews etc. It's very possible the issue has been corrected.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
