CA_Traveler
Aug 06, 2018Explorer III
Doug,
The NEC has the 80% rule for continuous loads which is defined as 3+ hours. Circuits and wiring can be rated for 100% but that is not common.
Since the OP has the problem with a few minutes of MW usage he could have low voltage or some other problem causing the CB to trip.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
