KJINTF
Aug 25, 2014Explorer
X2 with what westend said
Both Panasonic and Digikey
Panasonic is IMO the best you can get - when they go bad it's time to replace which is typically 25 to 30 years of service. Still going strong in my 1972 Pioneer power amp - all Panasonic caps
Could use a bit more info
If you supply a model # of the WFCO
I would be happy to check what values you will need
Suggest the Panasonic FR Series (sorry just checked they only go to 63Vdc, you will need 250 or 450 depending on the model, several other series will work) w/ 105C rating
Now if you decide it's too expensive we could always divert the shipment of the WFCO north to Montana :)-
Typically the larger 250Vdc / 450Vdc 2200ufd caps run $1.35 or so each with $2.50 in shipping (Domestic USA shipping)
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
