dougrainer
Jan 15, 2014Nomad
You remove the Water Heater and the Oven. THAT will give you access to slide the furnace curbside and out where the Oven is mounted. Remember, they build these to NOT always have adequate service access. They do NOT do it intentionally, but the end result sometimes is this. IF under warranty, the OEM would have to pay the extra time to remove the obstructions. From what I see, the outside door model could NOT be used in this case. Doug
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
