monkey44's avatar
monkey44
Nomad II
Jun 05, 2021
Mini-AC
Anyone know anything about these units??? Found it on the MCG site ... Not affiliated in any way with it.
https://coolsummertips.com/breeze.html?gclid=EAIaIQobChMIopWYosyB8QIVPRGtBh3tPAmREAEYASAAEgLhrvD_BwE
  • That's kinda what I thought. Seems every new - old? - device claims more efficiency than it can produce. Sells a bunch of them until folks figure out it ain't worth $200 bucks, then goes belly up.
  • Only suitable for extremely dry climates. Evaporative coolers can work but anything that small isn't going to help much.
    I bought a much larger one and quickly found that Saskatchewan, although "dry", and although real temperature in the RV was lowered, the comfort level was worse because of increased humidity.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Not that specific model but there is one beside me
    It is a combination of evaporative coolng and a small block of ice
    With a fan... Actually works but not nearly as good as advertised.
    In a SMALL room... it will make a small difference.
    I used to have a much bigger one. It did about 10 degrees in my bedroom.
  • It's called a Swamp Cooler, but on a small portable size, been around for years.
