lastword's avatar
lastword
Ductless AC instead of roof mounted AC
In addition to my roof repairs I am replacing the AC unit on my trailer.
Does anyone have any experience with the Mini Split Ductless AC Heat Pump reliability on an RV? I have seen installs on youtube and they all claim no problems with it. I worry about the bouncing going down the road causing a freon leak, But when I look at the construction of both roof and ductless I don't see significant difference in the build quality or design. So I'm thinking there should be no problem.
Planning to mount the outdoor unit and a generator to a welded platform on the rear of the camper and install a small brush guard and backup camera, and make sure the line-set is insulated and supported properly.
The unit I am planning to use ($460.00 delivered).
https://www.ebay.com/itm/12000-BTU-15-SEER-110V-Mini-Split-Confort-System-Ductless-AC-Heat-Pump-110V/303081116734
Says its good to 600 square ft, I have a little over 200, heating and cooling.
I have worked in manufacturing and installed and maintained many AC units. I have all the tools vacuum pump and hoses/gauges.
Thoughts? Sanity Check!
Looking for advice before your next adventure? Look no further.25,149 PostsLatest Activity: Jul 17, 2025
