ve7prt's avatar
ve7prt
Misbehaving PD9280 - A Bit Long
So, here's a good one. DW and I decide we're going camping Feb 8-11. I have the weekend off (amazing!), DW can clear her calendar that weekend, and the kids have Monday off due to the Family Day holiday. So we load up and head for Rathtrevor Provincial Park. I leave first as the kids get out of school 2pm Friday. Buddy of ours follows me down in his little Tracker and tiny trailer. We get camp setup, family finishes the trailer when they arrive. Now, it's just barely 0C (32F) out, so I have the heater going to start warming the trailer up.
Come to find out that we can't use the 35 odd gallons of water as I can't get flow via the pump. Pump's working, but almost no flow. Like this at both the inside sink and the outside valve. Hmm, line from pump to first Tee must be frozen. Leave the pump off. I do get full flow later Saturday, once the heater has managed (after a mighty struggle) to warm things up a little.
So, Saturday afternoon I look at the XBM, wow we've used some serious juice. Time to fire up Lil Red (Honda eu2000i). Well, Lil Red is a bit cranky due to the cold and not having been run in a long time. But, finally, after what must be 3 dozen yanks on the rope, she starts. Runs fine for a moment, but stalls just before I can apply loads. Yep, she's cranky all right. Get going again, and this time, she holds. Go inside and close the main breaker followed by the charger breaker. Pendent say PD9280 is in BOOST mode.
Look at the XBM - only 30Amps flowing into the battery bank. WTF?!?! :h We've used over 120Ah so far, this thing should be pushing out 80+ Amps!!!! I've even flipped the inverter off and her loads to shorepower. My first thought is the charger is uber cold and something may not be happy.
SO, it takes 2 hours, and we barely clear 60Ah back to the bank. And it wasn't an overloaded Lil Red, even with 2 chargers, fridge (That didn't even run once), space heater on low (750W). I'm starting to think Lil Red has an inverter issue - poor waveform as I've seen this behaviour with the PD9280 on other generators.
Sunday rolls around, XBM indicating 145Ah used. Yup, time to recharge. So, I flash up Lil Red, only takes 3 pulls this time. Don't think she likes the cold weather! Engage the charger, only to find again, at best 30Amps output?!? :h OK, something is really not happy.
So, fast forward to this past Tuesday (Feb 18). I have the morning to myself so I decide to head out and look at the charger. It did the same 30Amp output with the trailer connected to shorepower at home. So, now I'm thinking it's the charger.
First job, check the 3 30Amp fuses in case one or two of them popped. But, nope, all 3 are good. OK, so I guess it's time to bench the charger. That was a chore to get out of where it's mounted. I've already cut a 1ft square hole in the DS's bed to get to the thing. I find out real quick that the negative is grounded to the unit's case (and have a nice blister on my middle finger from where Alan Key burned me! :E:E). Get the unit through the hole, and the first thing I notice is something large is rattling around inside. Hmm, didn't do that when I installed it 6 years ago.:?
So, now the PD9280 is on the work bench. I still haven't got the case apart as there's a part of the bottom curled up and around the bottom of the heatsink. Kinda tough to move it. But, I did manage to pry the top open enough to peak inside and see that there are 2 large filter capacitors rolling around inside, completely disconnected from anything.:E Well, no wonder the thing isn't working right!
Now, if I can get that blasted case opened up I can either re-solder the caps into their respective spots, or I can get new ones and solder them in.
BTW, does anyone know how to open a PD9280 case?
Cheers!
Mike
  • RoyB's avatar
    RoyB
    Explorer III
    I guess parts floating around inside the case is a pretty good indication of something wrong...
    Just keep in mind the batteries determine how much current is being pulled. On my three GP24 Interstate 12VDc batteries in parallel if I run my bank down to around 12.0VDC over nite and then start charging with my PD9260C converter/charger I immediately see 14.4VDC with around 52-53 amps being demanded by the battery bank. This level starts dropping back within 15-20 minutes and levels out to around 8AMPs DC current until a two hour period goes by. Then the PD 9260c switches to 13.6VDC with around 6AMPS being demanded by the the battery for an additional hour of charge. It may then drop to 13.2VDC but as soon anything is demanded by the batteries it jumps back to 13.6VDC. Most of the time I see 13.6VDC on my meter panel unless the PD9260C goes into boost mode.
    When I get my 4ea Trojan T1275 batteries in place i will want to purchase the PD9280 unit I guess. I have had great luck with the PD9260C now for over 5 years of use...
    I have no idea why a couple of your caps have broken loose inside your case. My POPUP trailer is an OFF ROAD Model and things get bumped around pretty good but I would never think bumpy roads would cause some caps to pop loose.
    When you look at them I would be interested to find out if the capacitor leads were ever soldered in place.
    My PD9260C probably looks exactly like your PD9280. I have my PD9260C mounted to a wall just inside the trailer in a cabinet where the hot water heater is located within 5-6 feet from the battery banks mounted on the trailer tongue.
    My PD9260C has performed very well over the past 5 years of bumpy use camping off the power grid.
    Roy Ken
  • DryCamper11 wrote:
    Here are some labeled photos with some circuit info from my notes:
    I'm sorry the text is so hard to read, but it should be possible to identify the resistor that needs to be decreased in value (by adding a resistor in parallel) to increase the output voltage. these resistors relate to the microcontroller (lower left when seen from the top) which just changes the output voltage. The resistors that control current sensing, voltage sensing and current limits are covered in the patent.
    I'll also add that to get into the PD9280, there are two rivets that should be drilled out with a 1/8" drill and replaced with a 1/4" hex drive screw - like several other screws already on the case.
  • I would be calling PD service department.
    Progressive Dynamics
    Service Department
    507 Industrial Road, Marshall, MI 49068
    Pho: 269-781-4242
    Fax: 269-781-7802
    Service Dept. Fax: 269-781-8729
    Click to Email
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
