TC_Z
Apr 24, 2018Explorer
Thetford Toilet Misbehaving
We have a 2007 Winn MH.  It has a Thetford Aqua-Magic Lite toilet.  When you press the pedal halfway it used to fill bowl, then all the way flush.  But now even with the slightest pressure the waste ball moves and opens.  Seems like a linkage problem.  Pedal press should activate water valve first, later the waste ball.  Anyone know why the waste ball is activating immediately?  The waste ball also is not closing enough and allows water to seep out.
If I have to I plan to take it all apart, troubleshoot, repair, replace seals, etc. But posting this in case (hopefully) this is a known problem and there is a quick answer that I can fix without taking it all apart. Thanks in advance.
Always fixing something....
