MEXICOWANDERER
Dec 17, 2013Explorer
Batteries should be separated after the charging protocol. Connect all batteries together and apply 1 nominal 14.2 charging volts and there is no way any of the batteries can detect it one battery or a hundred are online, or the chemistry of any of them. The only requirement made of a charging system is that it not under or overcharge the battery. Voltage requiments for flooded 5% antimony batteries and pure lead AGM is similar enough for multiple warhead work.
It's when the charging ceases that the problems arise.
So go ahead and use a smart solenoid to parallel charge the batteries. I have done this too many times to count.
