westend
Jan 29, 2017Explorer
Yes, rated 100% at 13.2 but float voltage is specified at 13.6 V -> 13.8 V, similar to flooded deep cycle batteries.
If you want to give a set of AGM's their own particular regimen and want to gang up some flooded at the same time, a master "0,1,2" battery disconnect switch is all that is needed.
Or, if your wallet is full, you could do it like I did and use three switches and buses to control power to-from each bank connecting the inverter, the converter, and the solar charge controller. It was also a good thing that I bought 4 AWG wire in 100' quantity. I used a lot of #4 wiring up the switches and buses.
