Starburst2's avatar
Starburst2
Mixing AGM and Flooded Cell Batteries
Hi
I tried posting this question earlier today but it apparently did not go through. I have a mobile hotspot and in some locations the data transmission is spotty. Any way, here is my question.
My battery compartment measures large enough to hold 4x6 volt golf cart batteries but at present holds two 12 volt Trojan group 27 deep cycles and a 12 volt chassis battery. I need to beef up my storage capacity to 4x6V GC's but that requires me to relocate the chassis battery to somewhere else. There is a small sealed compartment right next to the battery bay but to use it would require non venting AGM batteries. My idea was to replace the chassis battery with an AGM and locate it in tne sealed compartment nearby. This would free up my battery bay for the 4x6 volt GC's. I have read that you are not supposed to mix AGM's and flooded cell batteries due to their uniqely different charging characteristics but would my idea work since the AGM would be charged by the engine alternator rather than my magnum inverter charger? Thus, I could equalize the flooded cell batteries without damaging the AGM. Is my assumption correct?
Thanks for your feedback.
Lloyd
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
