full_mosey
Jan 29, 2017Explorer
Float is not at rest so no problem connected.
When at rest, however, I believe the FLA will draw the AGM down first. The FLA will self discharge faster and simply draw the AGM down with it. Why would that be a design goal?
What is the AGM's SOC at the FLA's resting volts? How long will it take for the AGM to drop down to the FLA's resting Volts.
How about someone run a timed test to measure Amp flow from AGM to FLA when at rest?
HTH;
John
HTH;
John
