BFL13's avatar
BFL13
Explorer II
Jan 29, 2017
Mixing AGM and Flooded in a Bank ?
I have had no issues with my mixed bank of flooded 6v and 12s. I have a pair of Interstate GC2-XHDs, a pair of Exide 135s, and two Trojan T-1275s all banked. They are wired as two big 12s (4-6s + 2-12s)for loads and charging.
So I am looking at if any of those battery sets gets too weak (all from 2011) I might swap in an AGM or two. I have one 12v 100AH AGM I use elsewhere for now but could get another same kind to make a 200AH set.
Looking at the specs, I see the charging voltage for the Trojans is 14.8v and the AGM wants 14.5-14.9 The 6s are happy with 14.8 too.
Floating specs are also similar.
time2roll says you can float dissimilar batts because the float voltage covers all sins, unlike when they are all connected but not on a float, when all sorts of things go wrong amongst them. Seems to be true for my existing mixed bag of a bank. Working great for a few years now :)
I wonder about the higher resting voltage of the AGM(s) though. When camping and noting the AHs down on the Trimetric vs the "morning voltage" of the bank, would they no longer "match?"
With the lower R of the AGM I am also wondering if they will take more than their share of the amps in, even if the wiring is "balanced" But then the others might catch up before the charge is stopped?
What could possibly go wrong?----Thanks.
Having RV issues? Connect with others who have been in your shoes.24,323 PostsLatest Activity: May 15, 2020
