BFL13
Dec 22, 2014Explorer II
Ranger Smith wrote:
Connect the positive of 1 6 volt battery to the negative of the other. Connect the 2 remaining posts on the 6 volt battery to the corresponding posts on the 12 volt battery + to+ and - to - Load is on the + and - of the 12 volt battery
After you series the two 6s that is a 12v battery and then you parallel the two as stated. But the load should go across the whole bank, not just one of the 12s, to get proper "balance." (Although that only really shows when drawing from or charging the bank with high amps.)
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
