I'm not sure yet. US Battery gives fairly specific charging recommendations and bulk currents at 10% of the 20 hr capacity rate, which puts me at 13 amps, and max loading of my DC circuits is likely only 11.5 amps max while charging.
http://www.usbattery.com/usb_images/charging_instruction_2011_3.pdfI'd also like it to be able to charge my Northstar engine starting AGM battery (separately, via a moveable connector or switch), which likely wants a 0.4C rate when cycled, and that is a 90 A/h battery, so 36 amps for that. This battery is unlikely to be DC loaded during recharge, if I decide I am going to cycle it.
Still trying to determine which of the 3 brands I am considering most closely meets the voltage and amperage needs of both these batteries, separately. Also, I am limited to a 3.8" height, but length and width are more accommodating.
