tarnold wrote:
Op, both units have large bricks. The reperonics ASV and the O2 each require 2amp. So 7 hrs at night. Installed 2 new 230amp 6volts yesterday.
OP can you give all the data from the bricks?
Output voltage and watt or amp rating.
It looks like the ASV uses the same "brick" 80 watt transformer across most of their BiPAP as well as the DreamStation ASV unit.
DW has the dream station without the ASV and we have a 12 volt cord that powers hers straight from a cigar lighter style plug in the camper.
Your unit is more particular, and here is what appears to be the right 12 volt supply
shielded 12 volt supplyAt that price point, using a PSW large enough to handle both the asv and the separate O2 concentrator would likely make more sense.
