dougrainer
Sep 04, 2020Nomad
Your switch is rated at 5 amps MAX 12 volt. That means there are either relay's or a control module that runs the motor for the slide room. Usually the wall switch is a GROUND(Negative) powered switch. All it does is complete the Neg power to the control board or relay board. Now to the click you hear. On a Jayco, that is classis 12 volt CB tripping. Go to your 120/12 volt power center breaker box and have someone operate the slide to get that click sound. I will bet it is the CB tripping and it resets within 15 to 20 seconds. It may be as simple as they installed a 15 amp when the circuit needed a 20 amp. Your Model the Breaker box should be in the footboard of the Bed. If you lift the mattress you will see a sheet of wood paneling with a few screws securing it. Remove that wood panel and you will see all sorts of Converter and Inverter(if equipped) and Transfer box and the controls for the slide outs. Doug
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
