3_tons
Sep 04, 2020Explorer III
wa8yxm wrote:3 tons wrote:wa8yxm wrote:
The problem is more likely the slide out controller.. The problem is where the )Q(#@*$U#@! they hide those things.. I've had 2 controllers fail me.
FWIW, I have spent tons of time on a top to bottom scavenger hunt (even using a remote camera) trying to find my ‘ supposed slide controller’ with the same momentary switch with no luck whatsoever...Former Camper manufacture (now defunct) POC employee had no idea either...On an older thread I can recall one seemingly knowledgable individual say that his camper’s same maker PowerGear Slide-out set-up had no such controller... So far, no troubles for me (fingers crossed) but I’m still in the dark...
3 tons
Did same thing when my controller totally failed.
So cut the wires to the motor and built a "Manual" controller (no over current protection)
Finally got a cable tracker from harbor Freight hooked the transmitter to the leads from the controller and followed the cable bundle with the wand till I found the @#$@#)(($*@# COntroller.
On my rig it was in the basement. on the cealing in the Front end of the FRONT most compartment under the slide.. Logically it should have been ... farther back.
I appreciate your input Sir - so far all is good but I’m truly dreading the day that a gremlin of sorts decides to raise it’s ugly head - I like your smart wire tracer idea, and I’ll give a try on my next go around!
3 tons
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 24, 2026
